WMPG-6 High CPU Resources on MPGClient.exe
Adaptel
Post by Adaptel »
I have a WMPG-6 running on Acorn with Windows 11 and I am getting super-high CPU usage on MPGClient.exe whenever CNC12 is running (55-70% on just MPGClient.exe). System often peaks out at 100% and mouse gets jumpy. If I disable and disconnect the wireless pendant, CNC12 runs with TOTAL CPU consumption around 15-35%. Has anyone else had problems with high cpu resources using the WMPG-6?
report_E06234702C43-0430248195_2025-07-11_13-02-19.zip
(1.09 MiB) Downloaded 102 times
Re: WMPG-6 High CPU Resources on MPGClient.exe
I have WIN10, MpgClient 6-8% CPU usage.
Adaptel
Post by Adaptel »
If I had to take a wild guess what is going on, my PC only has USB 3.2 ports. Having a bit of experience with PC stuff, I have seen some other devices that were designed with USB 2.0 chips have strange issues when connected to a usb 3.x port. Is anyone else running the wireless pendant connected to a usb 3.x port with "normal" cpu usage? Any insight would be greatly appreciated.
jhnmdahl
CNC Control System Serial Number: C182115
Post by jhnmdahl »
N150 PassMark is 1911, which exceeds the required 1500 and is pretty common in really low end NUC-type devices. If it does end up a hardware problem, this NUC has dual Ethernet, Windows 11 preinstalled, and an i3-1220P with a PassMark of 3300 for $250: https://a.co/d/9IsRJXu
ah! yeah i jumped to quick, you must have something else going on, cpu is ok
jhnmdahl
Post by jhnmdahl »
Looks like the WMPG-6 is a WixHC unit that shows up as a generic HID-compliant vendor-defined device in Windows. It shouldn't need its own separate drivers, or consume a lot of CPU absent a whole ton of activity. I wonder if you have noise/interference at 433MHz? Or maybe batteries in the MPG are low? Seems unlikely, but worth investigating.
Adaptel
Post by Adaptel »
My batteries are new. The high CPU usage happens both when the pendant is powered on and when powered off, so it doesn't have anything to do with the communication between the pendant and receiver. I can try removing the antenna, and seeing if the high cpu usage persists (to rule out weather 433MHz noise is responsible). Other than that, I guess I will try to transfer my configuration to another PC (with an Intel i5 processor) to see if it is hardware related to my cheap N150 PC. I am away til monday, but looks there is no easy solution and I need to do some investigating.
spumco
Post by spumco »
Same problem here.
Pre-configured miniPC purchased from Centroid 4/2025 takes a long time to start up, and once running feels a little laggy. Checked task manager and mpgclient.exe is using 60-75% of CPU. Total load is bouncing between 90%-100% when CNC12 is idle.
WMPG-6 is in the front USB 3.2 port because the antenna adapter is too large to fit in the single rear USB2.0 port. Beelink for some reason flipped the 2.0 port's orientation and the antenna adapter interferes with the adjacent port due to it's thickness.
I'll try the WMPG-6 in the 2.0 port tomorrow just to see if it helps, but that won't work long-term as I also need a keyboard, touchscreen, and operator console external port.
Adaptel wrote: Thu Jul 17, 2025 10:11 pm If I had to take a wild guess what is going on, my PC only has USB 3.2 ports. Having a bit of experience with PC stuff, I have seen some other devices that were designed with USB 2.0 chips have strange issues when connected to a usb 3.x port. Is anyone else running the wireless pendant connected to a usb 3.x port with "normal" cpu usage? Any insight would be greatly appreciated.
Yes there are some problems with USB3.2 and high CPU usage, but they are not specific related to the WMPG.
I have only PCs with USB3.1 and no problems with high CPU usage regardless what is connected.
spumco
Post by spumco »
suntravel wrote: Fri Aug 08, 2025 3:00 am
Do you mean you don't have high CPU usage regardless of connected devices, or...
You do get high CPU usage, but that it doesn't cause problems?
Just curious as this is my first Centroid installation and I'm not sure what 'issues' can be ignored.
