Hiya
Do I got it right that for a mill the xyz = 123 on the db25?
Or is it zyx=123?
Xyz axis and pins <Answered>
Re: Xyz axis and pins
Free choice on the mill, only the lathe is fixed on XZ
- Tech Support
Generally, for a mill X is axis 1, Y is axis 2, and Z is axis 3.
With an Acorn, using the Wizard, you can change the DB25 pin mapping to whatever you like however.
Thanks guys
