Tool Touch Off does not trigger ATC program
guyvanloo
Post by guyvanloo »
I have this issue with a new install, this is the first machine with ATC that I convert, so i must be overlooking or misunderstanding something.
The atc change works fine until it is at the point that it has to measure the tool length. The z starts moving down, i see the visually see TT trigger, I get a "8075 WARNING: TOOL TOUCH OFF TRIPPED" but the program does not stop. It keeps moving down and i have to manually abort the program.
Hope anybody here can help.
https://share.icloud.com/photos/046OnBs ... FebFx9ae-g
report_20D77886DAC7-0623237341_2025-07-09_11-40-49.zip
(1.14 MiB) Downloaded 6 times
Re: Tool Touch Off does not trigger ATC program
hello.
what make model TT are you using?
does it open or close the input?
what does the PLC diagnostic screen look like when you trigger the TT by hand?
guyvanloo
Post by guyvanloo »
Thanks for your reply, i was on holiday, so a slight delay from my part. It is a tool touch off that came with the machine, an air piston, with a reed switch on the shaft. The Tool touch off is configured as mechanical, if i change to conductive i get the same behavure. The PLC diagnostic shows red in normal state, and green if triggered.
If i manually jog the Z down, i get the 8075, Tool touch off tripped, and it automatically stops the z axis. I can then untrip it by jogging the z up. It does however trigger quite late.
https://share.icloud.com/photos/032MMRI ... 6UU-MELEnA
please post photos of the machine and atc as well so we can understand what you are working with.
