Thanks ShawnM
I don't have screenshots of 5.3 because I had to reinstall 4.8 to keep my machine in production.
Over the weekend I will reinstall 5.3 again to troubleshoot and take screenshots.
I do appreciate the help and support!
Mark
Acorn 5.3 uprgade from 4.8 help with Tool Touch Off!
- CNC Control System Serial Number: E415F6F7742D-1204204101
Re: Acorn 5.3 uprgade from 4.8 help with Tool Touch Off!
So I installed the 5.3 Router version with the same result as with the Mill version, except now my license isn't valid? Do I need to go back and install the Mill version to utilize my license?
My tool touch off is NC, a cheapo from Amazon about 2.45 inches tall at the point of opening
Attached screenshots of where I am stuck:
https://gyazo.com/73706776ce7119e142cec662cd534307
https://gyazo.com/f133133f2eb5a00cf8649d66b17d464a
https://gyazo.com/d41b60307bb267d7ed9b4b5eabdd003e
https://gyazo.com/825ea0824f1e3d52f4814ae72f54c367
dang I don't see how to attach my report file? I think this is correct?
Thanks!
Mark
Thanks!
Mark
- Tech Support
Your Mill license is only valid with the CNC12 Mill software, it won't work with Router.
Regarding your 3rd image, You'll want to also have a "ToolTouchOffDetect" input.
I know you don't have a TT-4, but here's a schematic showing hooking it up with an Acorn:
https://www.centroidcnc.com/dealersuppo ... 087.r2.pdf
This could help give an idea of which wires to hook where with the TT you have.
