The Wizard supports the USB BOB for Acorn, Acorn 6, and Hickory. For other boards you will need to compile the PLC program yourself.
I would recommend trying to get one function working, then add functions on from there. The PLC code documentation from Centroid is very good.
I have an Acorn and was in the Alpha Testing. I still have some PLC code to modify for the additional functions I want to add ( non- standard application ).
Maybe looking at the reports from an Acorn or another board could help give you examples and clarify the code. I did look at Uwe's ( Suntravel ) report to figure out how he got some things working early on that weren't in the wizard.
Just a suggestion - change the subject of the post to what you are asking for to something like "USB-BOB for OAK, need help with PLC programming interface". We all get busy and know what we are asking when we post, but sometimes forget to prepare it to the audience we are speaking to.
From the bottom of the page on the "USB-BOB" page:
"When using the USB-BOB with the Centroid Allin1DC and Oak CNC control platforms there is no setup Wizard (like Acorn, AcornSix and Hickory), the USB-BOB is compatible with the Centroid Allin1DC and Oak CNC control platforms and is supported through a few CNC12 parameters (to let CNC12 know to look for a USB-BOB) and then the Centroid PLC program handles all the rest of the inputs and outputs for the USB-BOB. Note: For the Allin1DC and Oak it is required edit the Allin1DC or Oak CNC controller PLC program to match your custom inputs and outputs of the USB-BOB and then compile it. The Centroid PLC source code is human readable, open source and the compiler and even a debugger is all available for free. Instructions on how to edit and compile Centroid PLC programs are published and we also offer the PLC program modification as a service (purchase here) if you don't want to do it yourself. "
I just don't know enough about the Oak Board. I'll post an updated report on my build thread later this evening, you can look at that to see how the inputs are configured for the BOB.
viewtopic.php?p=101551#p101551
