NEW BUILD! Chinese CNC 1313 replacing mach3
Asdoyle1221
CNC Control System Serial Number: 880CE03450E7-0325259300
Re: NEW BUILD! Chinese CNC 1313 replacing mach3
Post by Asdoyle1221 »
Yet another mistake! I accidentally purchased the "mill" license instead of the router license....
Asdoyle1221
Hey fellas, I'm trying utilize cnc12mill while the office figures out what i need to do. I've got everything setup, everything homes properly, but when i try to lower the z it says "z axis travel exceeded." I looked again and the setting for z travel + limit is 6. I previously changed the limit to 7, but it did not stick. 'm sure its something simple, here is the report.
Thanks again!
Shane.
report_880CE03450E7-0325259300_2025-06-29_15-45-47.zip
(1005.26 KiB) Downloaded 36 times
Z "down" is negative. If your machine homes with the head all the way up, you are at max Z+, so your Z+ limit is 0, and your Z- limit is your max travel. You have a Z- limit of 0, so you will not be able to lower the head from the home position without hitting your travel limit.
Asdoyle1221
Thank you for the reply!
I tried that, but i keep getting an error saying "Value must less than equal to zero." No, thats not a typo, thats what the message says.
a negative value is less than zero...
Z axis travel limits:
Travel limit (+) should be 0
Travel limit (-) should be -6 (it needs to be a negative number)
Asdoyle1221
thanks!
Asdoyle1221 wrote: Mon Jun 30, 2025 1:14 pmthanks!
Do you know where else you could have found this into? Yup, you guessed it, in the install manual, just sayin' :mrgreen:
The info is on page 80 in case you were curious. :lol:
Asdoyle1221
I don't know how to read, do to a lack of proper education.
Asdoyle1221 wrote: Mon Jun 30, 2025 5:18 pm I don't know how to read, do to a lack of proper education.
At least we're finally getting to the root of the problem, this clears up a lot of questions I had. :mrgreen:
