VCP and external program launch
Make your own CNC Control Apps
Gerral
CNC Control System Serial Number: B4107B77A373-0905248481
Post by Gerral »
Is it possible to configure a button on the VCP launch an external program?
Thanks in advance.
Re: VCP and external program launch
You can run a macro with a VCP button and use M130 in the macro to run a system command.
10.48 M130 – Run System Command
This allows shell commands to be called from a CNC program or MDI. M130 takes one string argument which
contains the system command to execute.
Example:
M130 " mycommand .bat"
will run the batch file mycommand.bat.
Normally, the command will run asynchronously, meaning that the G-code program will not wait for the command to
finish before continuing. However, if an L1 parameter is given, the M130 command will wait until the “mycommand.bat”
finishes execution or an operator abort or fault occurs (such as E-Stop).
If you need to call a command that contains spaces in the path, then you must add escaped quotes around the path.
An escaped quote is a backslash followed by a quote.
Example:
M130 "\C:\ Users \CNC User \ myfile .bat \"
ASPeters
Post by ASPeters »
Gerral wrote: Wed Jan 15, 2025 5:39 pm Is it possible to configure a button on the VCP launch an external program?
Thanks in advance.
Yes, in the .xml for the vcp button you'll do
<vcp_button>
	<app>C:\path\to\your\program.exe</app>
</vcp_button>
This is how the plasma profile manager is launched in the plasma software. You can look at .\resources\vcp\Buttons\profile_manger for an example in your cnc12 install (all buttons are included with all software).
Gerral
Post by Gerral »
That works!
Thanks!
ASPeters wrote: Thu Jan 16, 2025 9:14 am
Thanks in advance.
<vcp_button>
</vcp_button>
i added this to the VCP manual along with image as a <background>, reference to color picker and edited the <run> section as well as other minor tweaks to improve the doc. here is the link. https://www.centroidcnc.com/centroid_di ... manual.pdf refresh your browser to get the latest version of the pdf with today's date.
corbin
CNC Control System Serial Number: 3484E42757Cd-1018248693
Post by corbin »
What version was <app> added?
I've been doing this to pass parameters to my application:
<vcp_button>
<run>
<line>M130 "C:\CNCM\ToolRackSetup.exe -showToolSetupWindow"</line>
</run>
</vcp_button>
ASPeters
Post by ASPeters »
corbin wrote: Thu Jun 19, 2025 10:28 am What version was <app> added?
<vcp_button>
<run>
</run>
</vcp_button>
v4.80 for Acorn, v5.00 for other boards
