hickory controler
hickory controler
i see DMM has new drive that does ethercat has it been tested with hickory
Re: hickory controler
DMM is making some changes for HICKORY compatibility.
Currently available drives are not compatible.
that's good to know
- CNC Control System Serial Number: 929110276
Has anything changed (DMM) here? Are the any other servo manufacturers in the line to work with Hickory?
John
John
DMM DYN5 compatibility is still in the works.
There are a few other drives nearly ready. We need to write the setup Tech Bulletins before announcing compatibility.
