Shuttle won't jog after program ran <Resolved>
fusion
CNC Control System Serial Number: 0479B7ADF2F3-1127192707
Post by fusion »
Hello,
Having trouble with my lathe. After running any program, the Shuttle won't jog or allow me to select an axis. The other shuttle buttons work as they should. I have to exit CNC 12 to get the jog function back.
Any idea why?
Mike
report_98038A53EB0B-0203259072_2025-05-26_20-14-18.zip
(1.09 MiB) Downloaded 2 times
Re: Shuttle won't jog after program ran
Do you have,a probe connected? The jogging inhibit is due to probe protect thinking your probe is tripped.
fusion
Post by fusion »
I do have a probe configured. It’s a conductive probe. Thanks for the tip. I never would have put that together with a jogging problem. I’ll turn off the probe protection in the wizard and see if that solves the problem.
Thanks!
Mike
fusion
Re: Shuttle won't jog after INTERCON program ran
Post by fusion »
It wasn’t the probe protection causing the shuttle jog to stop working. I turned it off and had no effect.
This is interesting. If I run a G code file it works just fine. If I use Intercon or the One Shot intercon functions on the VCP then the shuttle won’t jog. If I load an intercon G code file from the hard drive it’s fine.
So, to reiterate, loading programs from a drive and running them, the shuttle is fine. If I do anything using the Intercon interface, the shuttle jog stops working. VCP jogging is fine. Loading other programs after that is fine. Just no shuttle jogging.
Thanks for any help!
Mike
Your probe is not configured correctly. Correct that, and I bet your shuttle problem goes away.
05-26-2025 15:44:30 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:44:31 4042 Probe Cleared
(4)   05-26-2025 15:44:33 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:44:33 4042 Probe Cleared
(4)   05-26-2025 15:44:50 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:44:50 4042 Probe Cleared
(4)   05-26-2025 15:44:52 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:44:53 4042 Probe Cleared
(4)   05-26-2025 15:44:57 5060 Z AXIS SELECTED
(4)   05-26-2025 15:45:45 5061 X AXIS SELECTED
(4)   05-26-2025 15:45:46 5060 Z AXIS SELECTED
(4)   05-26-2025 15:46:01 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:46:01 4042 Probe Cleared
(4)   05-26-2025 15:46:03 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:46:03 4042 Probe Cleared
(4)   05-26-2025 15:46:08 5060 Z AXIS SELECTED
(4)   05-26-2025 15:46:53 5061 X AXIS SELECTED
(4)   05-26-2025 15:46:56 5060 Z AXIS SELECTED
(4)   05-26-2025 15:47:13 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:47:13 4042 Probe Cleared
(4)   05-26-2025 15:47:16 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:47:16 4042 Probe Cleared
(4)   05-26-2025 15:47:19 5060 Z AXIS SELECTED
(4)   05-26-2025 15:47:54 5061 X AXIS SELECTED
(4)   05-26-2025 15:47:55 5060 Z AXIS SELECTED
(4)   05-26-2025 15:48:09 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:09 4042 Probe Cleared
(4)   05-26-2025 15:48:12 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:12 4042 Probe Cleared
(4)   05-26-2025 15:48:17 5060 Z AXIS SELECTED
(4)   05-26-2025 15:48:17 5061 X AXIS SELECTED
(4)   05-26-2025 15:48:19 5060 Z AXIS SELECTED
(4)   05-26-2025 15:48:26 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:26 4042 Probe Cleared
(4)   05-26-2025 15:48:28 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:28 4042 Probe Cleared
(4)   05-26-2025 15:48:31 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:34 4042 Probe Cleared
(4)   05-26-2025 15:48:34 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:37 4042 Probe Cleared
(4)   05-26-2025 15:48:38 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:38 4042 Probe Cleared
(4)   05-26-2025 15:48:39 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:48:39 4042 Probe Cleared
(4)   05-26-2025 15:48:40 4042 Probe Cleared
(4)   05-26-2025 15:49:11 5061 X AXIS SELECTED
(4)   05-26-2025 15:49:14 5060 Z AXIS SELECTED
(4)   05-26-2025 15:49:40 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:49:40 4042 Probe Cleared
(4)   05-26-2025 15:49:42 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:49:42 4042 Probe Cleared
(4)   05-26-2025 15:49:45 5060 Z AXIS SELECTED
(4)   05-26-2025 15:49:51 5061 X AXIS SELECTED
(4)   05-26-2025 15:49:54 5060 Z AXIS SELECTED
(4)   05-26-2025 15:49:59 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:49:59 4042 Probe Cleared
(4)   05-26-2025 15:50:02 4042 Probe Cleared
(4)   05-26-2025 15:50:15 5061 X AXIS SELECTED
(4)   05-26-2025 15:50:18 5060 Z AXIS SELECTED
(4)   05-26-2025 15:50:36 5061 X AXIS SELECTED
(4)   05-26-2025 15:50:37 5060 Z AXIS SELECTED
(4)   05-26-2025 15:50:39 5061 X AXIS SELECTED
(4)   05-26-2025 15:50:43 5060 Z AXIS SELECTED
(4)   05-26-2025 15:51:02 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:51:02 4042 Probe Cleared
(4)   05-26-2025 15:51:04 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:51:05 4042 Probe Cleared
(4)   05-26-2025 15:51:09 5060 Z AXIS SELECTED
(4)   05-26-2025 15:51:11 5061 X AXIS SELECTED
(4)   05-26-2025 15:51:17 5060 Z AXIS SELECTED
(4)   05-26-2025 15:51:34 5061 X AXIS SELECTED
(4)   05-26-2025 15:51:53 5060 Z AXIS SELECTED
(4)   05-26-2025 15:51:55 5061 X AXIS SELECTED
(4)   05-26-2025 15:52:17 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:52:17 4042 Probe Cleared
(4)   05-26-2025 15:52:20 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:52:20 4042 Probe Cleared
(4)   05-26-2025 15:52:37 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:52:38 4042 Probe Cleared
(4)   05-26-2025 15:52:40 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:52:40 4042 Probe Cleared
(4)   05-26-2025 15:53:05 5060 Z AXIS SELECTED
(4)   05-26-2025 15:53:14 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:53:14 4042 Probe Cleared
(4)   05-26-2025 15:53:17 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:53:17 4042 Probe Cleared
(4)   05-26-2025 15:53:21 5071 PLEASE_SELECT_AN_AXIS
(4)   05-26-2025 15:53:22 5060 Z AXIS SELECTED
(4)   05-26-2025 15:53:28 5061 X AXIS SELECTED
(4)   05-26-2025 15:53:31 5060 Z AXIS SELECTED
(4)   05-26-2025 15:53:35 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:53:35 4042 Probe Cleared
(4)   05-26-2025 15:53:37 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:53:39 4042 Probe Cleared
(4)   05-26-2025 15:53:40 4042 Probe Cleared
(4)   05-26-2025 15:54:18 5061 X AXIS SELECTED
(4)   05-26-2025 15:54:21 5060 Z AXIS SELECTED
(4)   05-26-2025 15:54:43 5061 X AXIS SELECTED
(4)   05-26-2025 15:54:58 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:54:59 4042 Probe Cleared
(4)   05-26-2025 15:55:01 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:55:01 4042 Probe Cleared
(4)   05-26-2025 15:55:18 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:55:18 4042 Probe Cleared
(4)   05-26-2025 15:55:20 8040 WARNING: PROBE TRIPPED
(4)   05-26-2025 15:55:20 4042 Probe Cleared
(4)   05-26-2025 15:55:24 5060 Z AXIS SELECTED
(1)   05-26-2025 15:57:23 204 Exiting CNC...Normal Exit (66)
(1)   05-26-2025 20:01:16 199 CNC Started
(1)   05-26-2025 20:01:23 CNC12 Lathe v5.30
(1)   05-26-2025 20:01:23 490 Reset Initiated, Press Reset to Clear
(1)   05-26-2025 20:01:31 406 Emergency stop detected
(1)   05-26-2025 20:03:57 501 Invalid character
(4)   05-26-2025 20:04:25 5060 Z AXIS SELECTED
(4)   05-26-2025 20:04:32 5061 X AXIS SELECTED
(4)   05-26-2025 20:04:38 5060 Z AXIS SELECTED
(4)   05-26-2025 20:04:53 5061 X AXIS SELECTED
(4)   05-26-2025 20:06:38 5060 Z AXIS SELECTED
(4)   05-26-2025 20:06:39 5061 X AXIS SELECTED
(4)   05-26-2025 20:13:20 5067 FAST_JOG_SELECTED
(4)   05-26-2025 20:13:21 5068 SLOW_JOG_SELECTED
(1)   05-26-2025 20:14:18 Creating report...
fusion
Post by fusion »
Hi Tom,
What do I need to do to correct it?
I have it wired to input 7 and the chassis ground like the wiring diagram suggests.
What do I need to change?
I’ll go grab some screen shots of the settings.
I don’t understand why probe settings would effect this when I am seeing jogging differences between loaded G code and Intercon interface.
Mike
fusion
Post by fusion »
Here is a fresh report ad screen shots of the wizard.
report_98038A53EB0B-0203259072_2025-05-27_21-19-41.zip
(1.07 MiB) Downloaded 1 time
fusion
Post by fusion »
I looked at the msg file and see there are some API calls I don't recognize changing parameters.
(4) 05-27-2025 19:43:34 999 Parm #153 modified via api call: 0.00000 -> 1.00000
(4) 05-27-2025 19:43:36 999 Parm #244 modified via api call: 50007.00000 -> 0.00000
(4) 05-27-2025 19:43:36 999 Parm #244 modified via api call: 0.00000 -> 50007.00000
(4) 05-27-2025 19:43:42 999 Parm #911 modified via api call: 16.00000 -> 0.00000
Does this have something to do with my problem?
One more clue to this mystery, is I edited the PLC program so that the select axis would toggle between Z and X and not use the 2 unused axis. Did I break something there during that process?
Thanks!
Mike
fusion
Post by fusion »
Ok, I figured it out. When I use a G code program from a drive, the USB/Keyboard Jogging setting stays active. When I use an Intercon application, it turns off the USB/Keyboard Jogging. All I need to do it hit Alt-J and the Shuttle works again. Odd, but I can live with it.
Thanks for your help.
Mike
