Drive Fault on all drives
Moderators: cnckeith, Joey
Adam Saucier
Plasma CNC Controller: Yes
Re: Drive Fault on all drives - RESOLVED
Post by Adam Saucier »
dovrosenberg wrote: Fri May 09, 2025 8:29 am I resolved the issues I was having. I moved the wiring from the 24V screw terminals to the DB25 5V and removed the ENA+ and ENA- from my CL86T and CL57T stepper drives. I had to switch the drives from 24V (factory default setting) to 5V using the S3 switch next to the DIP switches. Even though the I had the latest version of the drivers that the docs say fully support 24V, 1 of the 3 CL86T drivers actually worked at 24v properly as expected. 1 seemed to have gotten fried. When I switched to 5v, the one driver that wasnt working started. The CL57T driver was totally non functional at 24V even with the switch set to 24v from the factory. I changed it over to 5V and now it is working. Someone on another Facebook group, said he was using CL86Y and CL57Y drivers at 24V with no problem
Awesome!!
