you can probably do this ATC with just a macro. i'm in the middle of several projects at once
I did do a Macro years ago (on Centroid) for an early Lathe Rachet / Pawl system which then discovered a bug which was since fixed. The 'method' is probably no longer the right way to do it but I did look at that again yesterday. That was entirely Macro based (I think).
no the PLC is on the main board so you need to be connected to a boardChaz wrote: ↑Thu Jun 20, 2024 4:58 amI did do a Macro years ago (on Centroid) for an early Lathe Rachet / Pawl system which then discovered a bug which was since fixed. The 'method' is probably no longer the right way to do it but I did look at that again yesterday. That was entirely Macro based (I think).
Let me see if I can work out how to do the same again for this application and start from scratch.
I know there is a version of Centroid that we can install to test stuff but not sure if there is a version that I can emulate without being at the machine all the time? That said, I've got wifi dongle coming later today, once I get teamviewer / similar installed, that should hopefully allow me to test from my office.
; Filename: mfunc6.mac
; Description: Tool Change Macro
; Notes:
; Requires: CNC12 V5.04
; Revision Date: 14 JUN 2023
; Please see TB300 or the following link for tips on writing custom macros.
; https://www.centroidcnc.com/centroid_diy/downloads/acorn_documentation/centroid_cnc_macro_programming.pdf
; Parameters:
; #9011 = Probe Input
; #9044 = TT Input
; #9160 = Enhanced ATC Features (Bins)
; #9161 = Maximum Tool Bins
; #9431 = 0 : Hole Style Holder
; 1 : Fork Style Holder
; #9432 = 0 : Fixed TT Position
; 1 : Surface Plate
; 2 : Tool Library
; #9433 = Surface Plate WCS Part 0
; #9830 = ATC Type, 0 = None, 1 = Carousel, 7 = RackMount
; System Variables:
; #4003 = Positioning Mode (G90/G91)
; #4120 = Requested Tool
; PLC Variables:
; ToolUnclampedState_M IS MEM12 (#70012)
; SpindleOrientedState_M IS MEM13 (#70013)
; SpindleZeroSpeedState_M IS MEM14 (#70014)
; AirPressureLow_M IS MEM15 (#70015)
; ToolChangeComplete_M IS MEM52 (#70052)
; AtPutbackLocation_M IS MEM59 (#70059)
; AtRequestedToolLocation_M IS MEM64 (#70064)
; CarouselInState_M IS MEM74 (#70074)
; CarouselOutState_M IS MEM75 (#70075)
; PutBackPosition_W IS W50 (#96050)
; User Variables:
; #101 = Saved Positioning Mode (G90/G91)
; #106 = Tool Touch Height
; #107 = New Tool Request Bin Location
; Return Points:
; G28 = Used For ToolCheck Position / M25 Home Positions
; G30 = Used for Z Height Flyover
; G30 P3 = X,Y,Z TT Location
; tt_check_configuration.cnc:
; #33001 = Tool Touch Input (Value from P11 or P44)
; #33002 = Fast Probe Rate
; #33003 = Slow Probe Rate
IF #50001 ;Prevent lookahead from parsing past here
IF #9006 == 0 THEN GOTO 950 ;Perform Default Macro if ATC not Installed
IF #9830 == 1 THEN GOTO 600 ;Jump to Carousel Section of Macro
IF #4120 == #9976 THEN GOTO 1000 ;Skip macro if requested tool is in spindle
IF #9160 > 0 THEN #107 = #[#4120 + 17000] ELSE #107 = #4120
IF #107 > #9161 THEN GOTO 800 ;Error Tool Change on Invalid Tool
; Carousel Tool Change Program Starts
N600
#101 = #4003 ;Save Positioning Mode
M109 /1/2 ;Disable Overrides
M5 ;Disable Spindle
M9 ;Disable Coolant
M107 ;Send PLC Tool Number
G4 P.25
G30 G91 Z0 ;Move Z to tool change position
G90
M94 /7 ;Request Tool Change
M101 /70014 ;Ensure Spindle at Zero Speed
;IF !#70013 THEN M19 ;Orient Spindle
;M101 /70013 ;Confirm Spindle Oriented
M101 /50037 ;Drawbar air pressure above 120psi
IF #96050 == 0 THEN GOTO 650 ;Skip putback
; Carousel Tool Putback Section
M101 /70059 ;Wait for carousel at Putback Position
G4 P.25
;Move Carousel in and Unclamp Tool
M101 /70059 ;Ensure carousel at Putback Position
M94 /62 ;Request Carousel in
M100 /70074 ;Wait for Carousel In
G4 P.5 ;Carousel debounce
G4 P1.5
M15 ;Unclamp Tool
;M101 / 50044 ;Check if drawbar is unclamped
; Carousel Tool New Tool Section
N650
G4 P1
G53 Z0 ;Raise head to Clearance
M94 /40 ;Set PutBackComplete
M101 /70064 ;Wait for carousel at Requested Tool Position
M95 /40
;IF !#70012 THEN M101 /70013 ;Confirm Spindle Oriented if not Unclamped
M100 /70074 ;Wait for Carousel in
IF !#70012 THEN M15 ;Request Unclamp if not already
M101 /50044 ;Check if drawbar is unclamped
M94 /61 ;Airblast on
G30 G91 Z0 L30 ;Move Z to tool change Position
G90
M95 /61 ;Airblast off
M16 ;Clamp Tool
M100 /50044 ;Check if drawbar is clamped
;M5 ;Turn off spindle and orient request
; Carousel Finish Section
M95 /62 ;Request Carousel Out
M100 /70075 ;Wait for Carousel Out
M101 /70052 ;Wait for Tool Change Complete
M95 /7 ;Reset Tool Change Request
M108 /1/2 ;Enable Overrides
GOTO 900
N800 ;Errors
M225 #100 "Invalid Tool Requested\nCycle Cancel to Abort"
GOTO 800
N900 ;Restore Modes
G#101 ;Restore Positioning Mode
GOTO 1000
N950
M6
N1000 ;End of Macro
Thanks, will take a look, much appreciated.Greg wrote: ↑Thu Jun 20, 2024 2:19 pm While memory bits are the preferred way to do things I also used simple input/output commands to the pre-configured file and it works perfectly fine too. Here is my frankenstein mfunc6, it has performed thousands of tool changes without a problem.
;------------------------------------------------------------------------------ ; Filename: mfunc6.mac ; Description: Tool Change Macro ; Notes: ; Requires: CNC12 V5.04 ; Revision Date: 14 JUN 2023 ; Please see TB300 or the following link for tips on writing custom macros. ; https://www.centroidcnc.com/centroid_diy/downloads/acorn_documentation/centroid_cnc_macro_programming.pdf ;------------------------------------------------------------------------------ ; Parameters: ; #9011 = Probe Input ; #9044 = TT Input ; #9160 = Enhanced ATC Features (Bins) ; #9161 = Maximum Tool Bins ; #9431 = 0 : Hole Style Holder ; 1 : Fork Style Holder ; #9432 = 0 : Fixed TT Position ; 1 : Surface Plate ; 2 : Tool Library ; #9433 = Surface Plate WCS Part 0 ; #9830 = ATC Type, 0 = None, 1 = Carousel, 7 = RackMount ; ; System Variables: ; #4003 = Positioning Mode (G90/G91) ; #4120 = Requested Tool ; ; PLC Variables: ; ToolUnclampedState_M IS MEM12 (#70012) ; SpindleOrientedState_M IS MEM13 (#70013) ; SpindleZeroSpeedState_M IS MEM14 (#70014) ; AirPressureLow_M IS MEM15 (#70015) ; ToolChangeComplete_M IS MEM52 (#70052) ; AtPutbackLocation_M IS MEM59 (#70059) ; AtRequestedToolLocation_M IS MEM64 (#70064) ; CarouselInState_M IS MEM74 (#70074) ; CarouselOutState_M IS MEM75 (#70075) ; PutBackPosition_W IS W50 (#96050) ; ; User Variables: ; #101 = Saved Positioning Mode (G90/G91) ; #106 = Tool Touch Height ; #107 = New Tool Request Bin Location ; ; Return Points: ; G28 = Used For ToolCheck Position / M25 Home Positions ; G30 = Used for Z Height Flyover ; G30 P3 = X,Y,Z TT Location ; ; tt_check_configuration.cnc: ; #33001 = Tool Touch Input (Value from P11 or P44) ; #33002 = Fast Probe Rate ; #33003 = Slow Probe Rate ;------------------------------------------------------------------------------ IF #50001 ;Prevent lookahead from parsing past here IF #4201 || #4202 THEN GOTO 1000 ;Skip macro if graphing or searching IF #9006 == 0 THEN GOTO 950 ;Perform Default Macro if ATC not Installed IF #9830 == 1 THEN GOTO 600 ;Jump to Carousel Section of Macro IF #4120 == #9976 THEN GOTO 1000 ;Skip macro if requested tool is in spindle IF #9160 > 0 THEN #107 = #[#4120 + 17000] ELSE #107 = #4120 IF #107 > #9161 THEN GOTO 800 ;Error Tool Change on Invalid Tool ;============================================================================== ;============================================================================== ; Carousel Tool Change Program Starts ;============================================================================== N600 #101 = #4003 ;Save Positioning Mode M109 /1/2 ;Disable Overrides M5 ;Disable Spindle M9 ;Disable Coolant M107 ;Send PLC Tool Number G4 P.25 G30 G91 Z0 ;Move Z to tool change position G90 M94 /7 ;Request Tool Change M101 /70014 ;Ensure Spindle at Zero Speed ;IF !#70013 THEN M19 ;Orient Spindle ;M101 /70013 ;Confirm Spindle Oriented M101 /50037 ;Drawbar air pressure above 120psi IF #96050 == 0 THEN GOTO 650 ;Skip putback ;------------------------------------------------------------------------------ ; Carousel Tool Putback Section ;------------------------------------------------------------------------------ ;M101 /70013 ;Confirm Spindle Oriented M101 /70059 ;Wait for carousel at Putback Position G4 P.25 ;Move Carousel in and Unclamp Tool M101 /70059 ;Ensure carousel at Putback Position M94 /62 ;Request Carousel in M100 /70074 ;Wait for Carousel In G4 P.5 ;Carousel debounce M100 /70074 ;Wait for Carousel In G4 P1.5 M101 /50037 ;Drawbar air pressure above 120psi M15 ;Unclamp Tool ;M101 / 50044 ;Check if drawbar is unclamped ;------------------------------------------------------------------------------ ; Carousel Tool New Tool Section ;------------------------------------------------------------------------------ N650 M101 /50037 ;Drawbar air pressure above 120psi G4 P1 G53 Z0 ;Raise head to Clearance M94 /40 ;Set PutBackComplete M101 /70064 ;Wait for carousel at Requested Tool Position M95 /40 ;IF !#70012 THEN M101 /70013 ;Confirm Spindle Oriented if not Unclamped M94 /62 ;Request Carousel in M100 /70074 ;Wait for Carousel in G4 P.5 ;Carousel debounce M100 /70074 ;Wait for Carousel in IF !#70012 THEN M15 ;Request Unclamp if not already M101 /50044 ;Check if drawbar is unclamped M94 /61 ;Airblast on M101 /50037 ;Drawbar air pressure above 120psi G30 G91 Z0 L30 ;Move Z to tool change Position G90 M95 /61 ;Airblast off M16 ;Clamp Tool M100 /50044 ;Check if drawbar is clamped ;M5 ;Turn off spindle and orient request ;------------------------------------------------------------------------------ ; Carousel Finish Section ;------------------------------------------------------------------------------ M95 /62 ;Request Carousel Out M100 /70075 ;Wait for Carousel Out G4 P.5 ;Carousel debounce M100 /70075 ;Wait for Carousel Out M101 /70052 ;Wait for Tool Change Complete M95 /7 ;Reset Tool Change Request M108 /1/2 ;Enable Overrides GOTO 900 N800 ;Errors M225 #100 "Invalid Tool Requested\nCycle Cancel to Abort" GOTO 800 N900 ;Restore Modes G#101 ;Restore Positioning Mode GOTO 1000 N950 M6 N1000 ;End of Macro
