My centroid control PC decided to do a windows update this afternoon. After that, every time I try and start a program in CNC12 Mill, I get a 9045 Z Axis Drive Fault error. The system no longer moves. Was working all week without issue. The timing coinciding with a windows update is too suspicious. Any ideas what this error code even means? Drive displays are not showing any faults.
I have tried everything I could from Tech Bulletins 270 and 309 without success.
9045 Z axis fault
- CNC Control System Serial Number: A901362
9045 Z axis fault
Re: 9045 Z axis fault
hello.
please follow the tech support request posting guidelines and provide detailecd information about your machine/project
starting by posting a fresh report.zip
Please follow these guidelines: https://centroidcncforum.com/viewtopic.php?f=60&t=1043sshield wrote: ↑Thu May 16, 2024 5:27 pm My centroid control PC decided to do a windows update this afternoon. After that, every time I try and start a program in CNC12 Mill, I get a 9045 Z Axis Drive Fault error. The system no longer moves. Was working all week without issue. The timing coinciding with a windows update is too suspicious. Any ideas what this error code even means? Drive displays are not showing any faults.
We need to know what you have to be able to help you troubleshoot.
This is one of the MANY reasons why your CNC PC should NOT be connected to the internet. A fresh report is needed to help you.
You can use a restore point before the update if you think the update is responsible for the problem.
