5.07 Rev15 and graphing bug <fixed>
Sword
Post by Sword »
This isn't 100% reproducible, but once powered up and homed, load a file, graph that file, maybe zoom/rotate/pan or double click on a line, and then click ESC, you are kicked back to the "Machine not homed" screen partially hidden under the code of the loaded file. The machine is sort of unhomed, with the DRO's set back to dashes. Hit cycle start to home again, graph again, wash rinse repeat, and it happens again.
With further testing, it seems that once you right click and rotate while graphing and then ESC, the "Machine Not Homed" returns and the DRO's are back to dashes. But then again, just going into graphing and ECS back will sometimes trigger it.
report_9884E39427E5-1206170338_2023-11-30_23-09-54.zip
(1.74 MiB) Downloaded 43 times
Scott
Sword
Re: 5.07 Rev15 and graphing bug
Post by Sword »
Confirmed this on a second machine as well. If you need a video, let me know.
Scott
thanks for reporting. It's fixed now.
The 64 bit version was writing to a bad memory address when removing the rulers to draw an isometric view of the graph. The memory address happened to coincide with the "machine_home_set" boolean.
Sword
Re: 5.07 Rev15 and graphing bug <fixed>
Post by Sword »
Thumbs up.gif (3.09 KiB) Viewed 4194 times
Scott
occustoms
Post by occustoms »
cnckeith wrote: Fri Dec 01, 2023 3:46 pm thanks for reporting. It's fixed now.
what about the Dro using wrong axis numbers? its in the video of mine you can see it. I had the 64 bit with rapid not working on fpr. if you watch the video x and z axis are wrong they are swapped.
yep we fixed that as well. rev16 soon.. then v5.08 release
occustoms
Post by occustoms »
cnckeith wrote: Mon Dec 04, 2023 2:23 pm yep we fixed that as well. rev16 soon.. then v5.08 release
dont think you did. it still messed up on mine
occustoms
Post by occustoms »
or is that on the next rev?
occustoms wrote: Mon Dec 04, 2023 7:36 pm or is that on the next rev?
i think you are running rev15.
rev 16 with the RTG X Z dro position flip fixed is coming out very soon. thanks!
occustoms
Post by occustoms »
cnckeith wrote: Mon Dec 04, 2023 7:38 pm
thank you for the clarification
