On two separate occasions, I have run into what seems like a loss of the G54 WCS while working on the same part for multiple days. As part of my routine, when returning to run a job, I enter via MDI: G52 Z0, G52 X0 and G52 Y0. I do this because I often use these commands while trial running g-code and want to be sure the local coordinate system has been reset to 0. I then enter G1 F10 X0 Y0 to visually see that my x and y positions visually look correct. I then jog to a safe place and enter G1 f10 z0 to verify the Z0 position looks correct. Just a bit of a habit that I always do.
On two occasions, while verifying my x0, y0 and Z0 positions... I notice they are not the same as the last time I ran the job. I virtually always use G54. I have never had this happen before using this Beta version. I have attached a recent report. I will be away for the next week so not sure if I can respond.
Thanks... Richard
Possible Glitch - CNC12 v5.07 BETA REV 12
- report_E415F6F649F8-0121214266_2023-11-20_17-21-07.zip
- (1.19 MiB) Downloaded 32 times
Re: Possible Glitch - CNC12 v5.07 BETA REV 12
i moved this post to the beta software forum
Thank you. I will wait for the next non-beta version before upgrading. Thanks for your reply.
