v5.07 rev 15 beta download now available. updated draft release notes attached.
https://1016.filemail.com/api/file/get? ... 9989ef1a64
changes from rev14
- fix for rapid override control with G99 in Lathe.
- added Plasma Profile folder full of material profiles specifically for Hypertherm 45XP cutter
- Implemented Parameter 496 to set USB com port for future USB connected hardware such as Future Centroid operator control panels
cnc12_v5.08_release_notes_rev15.pdf
(1.05 MiB) Downloaded 63 times
Re: v5.07 rev 15 beta download now available. updated draft release notes attached.
According to customer:
1) Rapid Override issue with G99 feed-per-revolution moves is fixed. Thank you.
2) Lathe X/Z axis cross-up on Current Position mini DRO, on Runtime Graphics screen, is not yet fixed. DRO still shows wrong axis positions.
cncsnw wrote: Mon Nov 27, 2023 6:12 pm According to customer:
thanks for the feedback.
we will fix #2 right away.
