Centroid CNC12 v5.07 REV12 BETA is now available.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Centroid CNC12 v5.07 REV12 BETA is now available.
Post by Nigelo »
Sword wrote: Thu Oct 26, 2023 1:04 pm ....but some that do not have an ATC may not figure that out right away and wonder why it's happening.
That is exactly my point.
Hope this helps
Nigel
RogDC
Post by RogDC »
Sword wrote: Thu Oct 26, 2023 1:04 pm I generally copy over the probing folder and the M6 along with my other custom macros after installing the betas, but before configuring anything in the Wizard (so that all my macros show up in the list for the VCP buttons).
I have configured the settings in the Wizard before copying over my custom macros from the previous version and the probing folder . I'll try to copy the custom macros before configuring in the wizard next time.
Nigelo wrote: Thu Oct 26, 2023 10:23 am Whooa, just caught up with the disappearing mfunc6.mac. I do not use an ATC BUT I do use a Custom mfunc6 with Swissi's ProbeApp.
Although we now know to set "Custom M6 Macro" in the ATC section, many other Users will not. Therefore suggest this is either moved to PREFERENCES section or duplicated
we duplicated it in cnc preferences.
Nigelo
Post by Nigelo »
cnckeith wrote: Fri Oct 27, 2023 2:29 pm
Perfect, thanks Keith
Hope this helps
Nigel
Sword
Post by Sword »
I've had an issue with how an MPG responds with the wheel in some of the past beta's (a CWP-4 in my case)... https://centroidcncforum.com/viewtopic. ... 658#p74658 ...It seems to be even more pronounce with v5.07r12.
I do have a coupe of videos I can upload, but it's not as easy to tell the difference between the release and the latest beta with them. In person, it's quite evident that the beta is more jerky or jumpy, for lack of a better description. I've tried the various MPG settings from smooth to quick response and it's noticeable with all settings.
Is there anything that has been tweaked with how an MPG responds? Maybe it's just my 4+ year old CWP-4, but it's very noticeable right away with 5.07r12.
5.06
https://youtube.com/shorts/1A1T16AJX30?feature=share
5.07r12
https://youtube.com/shorts/QQnsadgqYgE?feature=share
Scott
bleiler60
CNC Control System Serial Number: E415F6F2C7C9-0211214367
Post by bleiler60 »
I've had the same issue with the MPG (MPG-6)... set to the smooth response.
At times, using the hand wheel, there is bit of a delay and jerky motion.
Bill
RogDC
Post by RogDC »
Sword wrote: Wed Nov 01, 2023 6:24 pm I've had an issue with how an MPG responds with the wheel in some of the past beta's (a CWP-4 in my case)... https://centroidcncforum.com/viewtopic. ... 658#p74658 ...It seems to be even more pronounce with v5.07r12.
I noticed the same issue with 5.07r12, configured smoothing for 3D relief and seems to be better less jumpy. On my machine it was very noticeable with the speed at x100. I mainly use my WMPG4 for jogging, not the VCP, maybe I need to do more testing to determine if it's the WMPG4 or prevalent in both modes.
RogDC
Post by RogDC »
Experienced delayed movement with the WMPG-4 last night, no video, but not getting consistent performance. Movement was jerky, and intermittently delayed from WMPG-4 commands.
RogDC wrote: Thu Nov 02, 2023 3:50 pm Experienced delayed movement with the WMPG-4 last night, no video, but not getting consistent performance. Movement was jerky, and intermittently delayed from WMPG-4 commands.
thanks, there have been no specific changes in WMPG motion in v5.07 beta, but we are looking into it to see if something else has effected it in some way.
doing test's today comparing v5.06 to v5.07 r13 beta.
Joey
Post by Joey »
5.06
5.07r12
Scott can I have a fresh report . Trying to pinpoint the R13 WMPG Motion over here.
I noticed that the 5.06 video has a faster MPG jogging rate than the R13 video. The R13 WMPG was jogged at a slower less consistent rate
Locked
