Centroid CNC12 v5.07 rev8 BETA is now available.
Re: Centroid CNC12 v5.07 rev6 BETA is now available.
suntravel wrote: Tue Oct 03, 2023 12:42 am
suntravel wrote: Sat Sep 30, 2023 9:34 am New issue:
I have only Probe Detect and Probe Tripped as inputs, using them for Tool Touch Off too.
With 5.07 on Acorn Mill this will not work, stops with message TT0 Input not set in PLC.
I have had to set the Input to ToolTouchOffTriggered.....
The Probe will work this way, pls. change this back so TTO and Probe could use the same input.
Same on the lathe, I you use Probe as inputs, the input is also set for TTO in the wizard, with TTO only for the TTO.
But setting up tools with Probe input is not possible.
Not an issue on my lathe, since I have only TTO an free inputs, but on my mill no free inputs and sharing Probe with TTO worked perfectly up to 5.04
Why was this changed, and could we go back pls ?
Schematic S15122 shows also it should be possible to share Probe input with TTO.
thanks, we fixed another users 'issue' and apparently broke it for you.. thanks for reporting it... today we fixed it again :-) so now it works with both. new revision hopefully today for you to try out..
Cool, that this is not an evil plan to sell more Ether1616 :lol:
Re: Centroid CNC12 v5.07 rev8 BETA is now available.
Update. Rev8 is now available. 10-4-23
https://centroid-support.filemail.com/d ... ipreg=true
changes in rev8
37. Made Rapid Override VCP skin the default skin for Acorn and AcornSix and set parameter 264 3 to activate rapid override control and display it by default.
38. Installer will now rename the cncm/cnct directory to be the backup instead of making a copy of it. This results in faster install times and doesn’t change the dates of the files contained in the cnct/cncm directories which makes updating easier.
39. ALLIN1DC Lathe ATC Hardinge PLC: Fixed issue with Jogging 1st and 2nd axis in the PLC program.
40. Fixed issue in AcornSix, Oak, ALLIN1DC, and Hickory PLC's that caused WMPG Macro buttons 1-4 to be unresponsive after pressing Macro 4 button.
41. Wizard now explicitly sets probe and tool touch parameters to both look at the probe inputs if tool touch inputs are not set up
That was fast, I will give it a run tomorrow.
cnckeith wrote: Wed Oct 04, 2023 3:34 pm Update. Rev8 is now available. 10-4-23
changes in rev8
507R8 running on my mill.
37. nope, if select Diagonal Skin in the Wizard, Skin without Rapid is installed. P#264=3 ok
38. cool
41. Yeah, now TTO and Probe are working together
Feedrate overlaps with Rapid button.
suntravel wrote: Thu Oct 05, 2023 1:55 pm
changes in rev8
38. cool
thanks!! glad the probe stuff is working for you.
sounds like we still have some house keeping to do so we'll clean up the diagonal skins
on the over lap.. you must be using the old feedrate_override.svg? i can't get the new one to act like this.
i've attached the one i'm using.
(8.08 KiB) Downloaded 36 times
I use the one from the fresh install, nothing changed.
But I will try the one above.
Sword
Post by Sword »
I'm seeing the same overlap with the attached feedrate_override.svg. Since you are using "Rapid", why not just use "Feed" instead of Feedrate? Solves the size issue. ;)
Scott
Sword wrote: Sat Oct 07, 2023 4:02 pm I'm seeing the same overlap with the attached feedrate_override.svg. Since you are using "Rapid", why not just use "Feed" instead of Feedrate? Solves the size issue. ;)
That is what I did...
thanks, yeah i get that but, i want to know why you guys are seeing overlap when i don't, :? .
if i don't know why this is happening it will happen again on something else.
Locked
