Release Candidate #4 now available. download Centroid CNC12 v5.0 RC#4
Locked
OLD THREAD, LEFT HERE FOR HISTORY PURPOSES
Latest release version of CNC12 is HERE
Now available for download Centroid CNC12 v5.0 RC#4 for Acorn, AcornSix, Oak, Allin1DC, Hickory and MPU11 CNC controller platforms.
Please download and test so we can flush out any remaining issues before turning this into an official release. thanks, in advance for your testing efforts!
Download CNC12 v5.0 RC#4
This is a Free Centroid CNC Software download for anyone using the Acorn, AcornSix, Oak, Allin1DC, and MPU11 CNC controller platforms.
- All existing License files work with v5.0
- All features from previous versions of CNC12 are included in v5.0
- Release Candidates DO NOT have count down timers and do not expire
Full release notes of changes from v4.82 Acorn and v4.22 Oak/AllinDC
Acorn and AcornSix users follow the Acorn installation instructions.
In general.
1.) Make screen shots of your current Wizard screens and create a fresh report.zip of the current running CNC12 software.
2.) Download ZIP file from the link above, extract zip file to desktop (don't run the installer from inside the zip file)
3.) Run the installer, use the Wizard to reconfigure the CNC controller for Acorn and AcornSix. For oak/allin1dc/mpu11/hickory configure using parameters menu.
Do not use the "restore report" feature.
Oak, Allin1DC,MPU11 users follow software installation instructions in the Oak or Allin1DC install manuals.
As always make sure the CNC PC meets the requirements to run this version of CNC12 software.
A CNCPC Windows requirement is to update Windows 10/11 to the latest .net framework (the new VCP requires this)
Advice.
- Do not install on a machine used for Production.
- Do not install on a customer of yours machine
- If you have a custom PLC program and are not familiar with PLC programming and compiling do not use this beta
That being said, have no fear! If desired, it is very easy to switch back to the previous version of CNC12 that you were running.
Before the new install, make a copy of the current working c:\cncm or cnct directory, save it somewhere safe. After installing the new version of CNC12 if you want to switch back to the previous version of CNC12 that you were running. Simply rename the beta cncm/cnct directory and then copy back the previous cncm or cnct directory. Its that easy.
Acorn Install Manual.
AcornSix install manual.
Re: Release Candidate #4 now available. download Centroid CNC12 v5.0 RC#4
**UPDATED 6-14-23**
Centroid CNC12 v5.04 has been released. Click here , refresh page to download. https://www.centroidcnc.com/centroid_di ... loads.html
This is a Free Centroid CNC Software Upgrade for anyone using the Acorn and AcornSix CNC controller platforms and for anyone using v4.16+ on Oak, Allin1DC, MPU11 or Hickory.
- Since the Centroid Acorn CNC controller release over six years ago (August 2017) every new Acorn CNC12 version has been free of charge.
- All existing License files work with v5.04
- All features from previous versions of CNC12 are included in v5.04
v5.04 Release notes.
1.) Fixed Acorn Limit Switch defeat button functionality. (skin event number in the button xml was in inadvertently not updated in previous version v5.0/v5.02)
2.) Fixed Oak/Allin1DC/MPU11/Hickory VCP Aux 13-16 (the controlling CNC12 parameters were off by one) which were incorrectly configured.
3.) Fixed Acorn VCP button Mill Vac On/Off skin event number (skin event number in the button xml was inadvertently not updated in previous versions v5.0 & v5.02 )
4.) Added an all new DXF import “engine” for Plasma Intercon DXF import feature. Now the new DXF import supports a wider variety of complex arcs commonly generated by graphic art programs.
5.) Some Color picker additions the Plasma restart graphical menu. blue, red, and purple dots which represent the pick up point, jog off point, and interrupt point
6.) In the Utility menu “Create Report” now copies the Wizard generated Acorn/AcornSix ATC macros to the Report.zip file.
7.) Updated Skin call “GetMachineType” it will now also return “emulator” for offline use.
8.) In Acorn and AcornSix it is now possible to mix and match HomeAll with other HomeOk inputs for example:
and the Wizard generated home program will work using all of the defined homeok inputs in addition to HomeAll.
9.) Added auto detection skin call so AcornSix Wizard will auto detect the AcornSix Encoder Expansion Board. "IsENCEXP12Connected"
10.) Fixed M1 functionality which was broken in AcornSix, Oak, Allin1DC, Hickory, MPU11.
11.) Fixed M0 jogging which was enabled regardless of what Parameter 10 was set to.
12.) Moved the TT Fixed location from the ATC menu to the Tool Touch menu in the wizard.
13.) Added WCS Lockout Parameter to Lathe (parameter 426). WCS Lockout was previously only available in Mill/Router/Plasma and was controlled by parameter 45
14.) Added easy control of ATC fork engage and disengage speed in the Wizard ATC setup page for Acorn and AcornSix
15.) Pro Plasma License now includes unlimited block Teach/Trace mode and DXF import Blocks with Plasma Intercon.
16.) added DXF colors to the color picker
17.) Added Wizard ATC menu tool change “Flyover” Z height position clearance position. This is the height that the Z axis goes to in between the tool put away and the new tool (flying over the tools). This is a machine coordinates value. ( Note: Previous version used hard coded (in the macro) machine coordinate Z0. Now user can specify tool clearance Z height from one tool position to the next.) This value is set in the Wizard ATC. The Wizard writes this value to the CNC12 G30 position and the Wizard generated ATC macros use G30 to command movement to the flyover position.
Note: the Acorn and AcornSix ATC Wizard setup page currently supports 16 pockets for Rack Mount setups, but the user can “manually” add as many additional tools to the Rack mount setup as they like. The future Wizard ATC menu will support more pockets so the user doesn’t have to copy/paste and edit files to add more than 16 pockets.
For example to add four more pockets for a total of 20, navigate to the C:/cncm/system/rackmountbins folder, ATC pocket files called: tool#position.cnc (Where # is tools 1-16). Copy anyone of these files and create a Tool 17 file from it: “tool17position.cnc”, then do the same for Tool 18 “tool18position.cnc”, etc..etc.. Ensure the naming is identical to the others so tool17position.cnc, tool18position.cnc and etc. Then edit the X, Y, Z positions and the other lines within these new tool position files for that tool. The macros are commented so it is simple to understand how they work.
Locked
