Release Candidate #4 now available. download Centroid CNC12 v5.0 RC#4
Posted: Wed Apr 19, 2023 4:46 pm
OLD THREAD, LEFT HERE FOR HISTORY PURPOSES
Latest release version of CNC12 is HERE
Now available for download Centroid CNC12 v5.0 RC#4 for Acorn, AcornSix, Oak, Allin1DC, Hickory and MPU11 CNC controller platforms.
Please download and test so we can flush out any remaining issues before turning this into an official release. thanks, in advance for your testing efforts!
Download CNC12 v5.0 RC#4
This is a Free Centroid CNC Software download for anyone using the Acorn, AcornSix, Oak, Allin1DC, and MPU11 CNC controller platforms.
- All existing License files work with v5.0
- All features from previous versions of CNC12 are included in v5.0
- Release Candidates DO NOT have count down timers and do not expire
Full release notes of changes from v4.82 Acorn and v4.22 Oak/AllinDC
Acorn and AcornSix users follow the Acorn installation instructions.
https://www.centroidcnc.com/centroid_di ... ctions.pdf
In general.
1.) Make screen shots of your current Wizard screens and create a fresh report.zip of the current running CNC12 software.
2.) Download ZIP file from the link above, extract zip file to desktop (don't run the installer from inside the zip file)
3.) Run the installer, use the Wizard to reconfigure the CNC controller for Acorn and AcornSix. For oak/allin1dc/mpu11/hickory configure using parameters menu.
Do not use the "restore report" feature.
Oak, Allin1DC,MPU11 users follow software installation instructions in the Oak or Allin1DC install manuals.
As always make sure the CNC PC meets the requirements to run this version of CNC12 software.
A CNCPC Windows requirement is to update Windows 10/11 to the latest .net framework (the new VCP requires this)
Advice.
- Do not install on a machine used for Production.
- Do not install on a customer of yours machine
- If you have a custom PLC program and are not familiar with PLC programming and compiling do not use this beta
That being said, have no fear! If desired, it is very easy to switch back to the previous version of CNC12 that you were running.
Before the new install, make a copy of the current working c:\cncm or cnct directory, save it somewhere safe. After installing the new version of CNC12 if you want to switch back to the previous version of CNC12 that you were running. Simply rename the beta cncm/cnct directory and then copy back the previous cncm or cnct directory. Its that easy.
Acorn Install Manual.
AcornSix install manual.
In general.
Advice.
