cwp-4 not connecting to oak
Posted: Sun Apr 16, 2023 8:53 pm
by occustoms
Hi i have an oak with CWP-4 wireless pendant and it doesn't connect to oak. I use it acorn and works just fine. It sees receiver reception. so here is a report.
when i select an axis and turn mpg, windows makes a sound but no pop up window or errors. and nothing under my properties has any driver issues.
Re: cwp-4 not connecting to oak
Posted: Mon Apr 17, 2023 3:12 am
by cncsnw
The CWP-4 connects to the computer, through USB and Windows; not directly to the Oak or Acorn.
Have you tried using the computer from your Acorn control to run your Oak control; or vice versa? You can do that, simply by renaming your c:\cncm or c:\cnct directory, then installing the appropriate CNC12 version and restoring a Report.
Posted: Tue Apr 18, 2023 4:28 pm
by occustoms
cncsnw wrote: ↑Mon Apr 17, 2023 3:12 am
yes im aware it connects to computer usb. i can see in the Hid under property management that its connecting and disconnecting for pc. I use this wireless on a diff lathe and a router and both work fine. Tired different usb ports and even bought an pci express to usb3.1 card to see if it was something from main board.
cant connect use computer from acorn on oak as the plc and stuff is way different.
Posted: Thu Apr 20, 2023 2:12 pm
hi i moved this thread into the beta test forum.
Posted: Sat Apr 22, 2023 3:15 pm
by occustoms
cnckeith wrote: ↑Thu Apr 20, 2023 2:12 pm
It was doing the same thing before i did the beta software upgrade.
Posted: Mon Apr 24, 2023 3:18 pm
occustoms wrote: ↑Sat Apr 22, 2023 3:15 pm
post photo of the wireless LCD screen when CNC12 is running
