In the last few versions, there are a couple of graphical issues. When using cycle start from the graphing screen, there's a good size chunk of the graphing screen that stays onscreen.
Also, when scrolling up through the MDI list with the arrow keys, the list runs off the bottom into the active G-code section by two lines. Perhaps intentional, to see the last two below the entry box?
A couple of graphical issues
Re: A couple of graphical issues
Thanks for Pointing those out Scott! Fixes are in the next build.
I usually have RTG on so I dropped the ball there testing. Glad you brought that up!
Also never had to scroll thru that many MDI commands with G/M codes displayed.
