Requested feature for the new 5.0 if possible. When I plasma cut repeated parts I turn repeat on of course and say I type 25 for the number of parts and press cycle start, is there a way on the screen on the left column under the speed and voltage readings that you can place a part counter? Up or down?
Or is there already one on another screen that I don't know where it's hiding?
Now available for download CNC12 v5.0 rev0 Beta
Re: Now available for download CNC12 v5.0 rev0 Beta
That is in the standard status window, in the upper right quarter of the main CNC screen.
If you are on the runtime graphics (RTG) screen, press F8/GCode to return the display to the main CNC screen, with the full status window.
Thanks Marc, I'll have a look on the next run. Once I start the cycle I never thought to swap screens off the RTG screen to look for it. I have a dwell at the end on the cut cycle that gives me just enough time to load the next part and catch my breath before it starts to cut the next part. I lose track sometimes and it would be great to see how many I've done or have left in the repeat cycle. Thanks for your help.
Shawn! We haven't had much plasma testing. Are you running the latest 5.0 release? I'm guessing you would of mentioned an issue if you noticed one. Can you update to this build and let me know what you think of it with Acorn plasma?ShawnM wrote: ↑Tue Apr 18, 2023 8:39 pm Thanks Marc, I'll have a look on the next run. Once I start the cycle I never thought to swap screens off the RTG screen to look for it. I have a dwell at the end on the cut cycle that gives me just enough time to load the next part and catch my breath before it starts to cut the next part. I lose track sometimes and it would be great to see how many I've done or have left in the repeat cycle. Thanks for your help.
I locked this thread. CNC12 v5.0 RC#4 will be posted shortly.
