new one hit buttons question
Re: new one hit buttons question
Good catch Tom,
did not expect someone would try this
Well, I just about give up, reinstalled rev 6 and same things happening. I thought the date was taken from the pc? Look at the video, i'm not opening intercon?
- bizarre.mp4
- (5.59 MiB) Downloaded 8 times
- report_74E1829FB66D-0312191755_2023-03-16_14-39-03.zip
- (959.97 KiB) Downloaded 8 times
Did you delete the C:\icn_lath folder before the installation of R6?
No, sounds like I should have done? How are you supposed to know theses things? What now, can I delete said file and reinstall?
Yes, because now you have kept the messed up one shot files...
...2004 is the date the file was created, not the actual date.
There is really a bug in R6, after using one shots and going to CAM they are loaded in Intercon.
No good, easy to overwrite them this way...
This is what I've been trying to say but I just got told I was trying to open them in intercon (which I knew I wasn't)
There are other bugs too, after running the oneshot , they too are changing the dro readout for some reason.
This is no bug only the tool offset is unloaded.
Try in MDI T0101 and after this T0100 if you have offsets in 01 the DRO will change.
Not a bug, but certainly an undesirable feature.
Centroid should change Intercon so that when it posts from a one-shot program, it refrains from canceling tool offsets.
wait for rev7 in this regard. hope to have rev7 soon, we are testing it now.
