C-axis setup with 4.99R6 Acorn and Acorn6 lathe
Manual how I set up C-Axis on my lathe with Acorn6
I also made a benchtest with Acorn
C and Y axis are running as expected with 4.99R6
Maybe there will be sone changes in setup with final version.
DriveCalc.xls
(14 KiB) Downloaded 20 times
CAxis _Manual499.pdf
(1.49 MiB) Downloaded 54 times
Re: C-axis setup with 4.99R6 Acorn and Acorn6 lathe
awesome, thanks for posting.
cnckeith wrote: Mon Mar 06, 2023 2:42 pm awesome, thanks for posting.
At this moment already outdated. :lol:
Chris figured out a better M51 macro, with some tweaks now this should work for all configurations.
Waiting for his ok before I post it.
cool. we will integrate this knowledge into a C axis setup page in the Wizard at some point to make it an 'easy button' for C axis configuration.
cnckeith wrote: Mon Mar 06, 2023 3:00 pm cool. we will integrate this knowledge into a C axis setup page in the Wizard at some point to make it an 'easy button' for C axis configuration.
Not sure if we need a C-Axis page, right now it works with only selecting C in the Axis configuration.
New mfunc51.mac takes care of with encoder or not, if ThirdAxisHome NPN is installed, if VFDZeroSpeed input is used or not
But if C Axis is selected, would be nice that the Wizards sets P93 =145 and generates a C-Axis button on the VCP
One other thing missing is a Alarm Message if spindle is tried to turn on with M51 active. It turns not on (thats good), but if M3 in a program with M51 active, it continues happy with a non rotating spindle.
