Now available Centroid CNC12 v4.99 rev6 BETA
Re: Now available Centroid CNC12 v4.99 rev6 BETA
i hope to post it later today. testing now.
midy
Post by midy »
great thanks
we are working on one last issue before going public with rev 7
here is a preview of the changes and additions in rev7
- Reworked probe input (trigger and detection) firmware to unify logic across all hardware platforms. Needs tested, Note: since this is ‘low level’ change be cautious on your testing, hand trigger probes before running a probing cycle to verify proper operation.
- Added user variables #27901-27908 for the axis home rate. Typically set by Wizard. But also can be used for custom home programs. Example M106/X P1 F#27901 ; seek home switch in X positive, look for input 1, move at feedrate specified by value in #27901
- Fixed issues importing licenses when they had lines terminated with non-Windows line endings. Reduces support issues related to users downloading license.dat file on non windows devices.
- Added F3 "Machine Notes" button in User Maintenance menu to open "machine_notes.txt" from cncm or cnct folder in text editor. Terry R asked for this so he can save a .txt file with any notes about the machine and control customizations and obvious other uses.
- Added Clearpath Hard Stop homing option and supporting home routine in homing wizard see TB319 for more info. https://www.centroidcnc.com/dealersuppo ... ds/319.pdf
- Added one shot selections to the Wizard VCP aux key assignments page for mill/router and lathe needs tested.
On going discussion on how Lathe one shots are working in regards to offsets is here.
https://centroidcncforum.com/viewtopic. ... 8903e0bbf9
- Fixed issues with MPG/jogging not working correctly under some probe/tt configurations.
- Fixed problem where the probe status was not updating graphics as the probe trip/detect input would change.
- Removed Plus/Minus homing rates in exchange for one homing rate in the Wizard.
- To avoid unexpected movement, Keyboard jogging will disable itself and re-enable when leaving and entering the main menu. KB jogging can still be enabled in any menu by alt+j after being disabled by cnc12. For instance if keyboard jogging is active and user navigates to the CNC12 parameters menu, cnc12 will suppress keyboard jogging while in that menu and reactivate it when navigating back to the main menu of CNC12.
- Plasma Intercon: Added support for the DXF entity LWPOLYLINE
- “Fixed or Slider” Carousel ATC type added to the ATC Wizard setup menu.
- Added system variable SV_PLC_DISABLE_TRAVEL_LIMITS that can be set by a PLC program to disable travel limits when jogging or using the MPG. Example: IF INPUT THEN ( SV_PLC_DISABLE_TRAVEL_LIMITS)
- Removed RedOak and added Oak, AllInOneDC, and Hickory to skinning call GetMachineType. RedOak removed due to no support on cnc12 side
- VCP plc words now scales better in other 16:9 aspect ratio monitor resolutions other than the recommended 1920x1080.
- Keyboard Jog Panel legend was missing from Router and Plasma now restored.
- Fixed some cases of parsing errors with M120, M121, M223, M225, G65, and string user variable assignments when a semicolon appeared in a quoted string.
- Wizard AcornSix Scale menu bug reported by Uwe fixed.
- Standardized and consolidated Allin1dc Mill PLC programs included with the CNC12 installer. This is the beginning of an overhaul of the “Stock” PLC programs included with the CNC12 installer with the goal to make PLC program selection for Oak and Allin1dc less confusing by improving standardization and eliminating old outdated files.
- renamed ncfiles\stressTest.cnc to “com_stress_test.cnc”, left a copy of old stress test for now. No difference in the files, just a renaming.
- report.zip report now names the hardware AcornSix, Hickory, Oak, Allin1dc etc instead of generic “servo”
Locked
