Downloaded the 4.99 software and installed and set up with no issues Then set up the ATC and it work with one exception
I wrote a ATC test program that just cycles through all the tools as it should. I have a Auto tool touch installed and it works as it should but when i run the ATC program it wants to touch off the tool every time it does a change is there a setting in the wizard to bypass the Auto tool touch off once the tools are set. I have this on my test bench hooked up to motors but not on a machine so i trigger the touch off manually when I see it reach the tool change position and start moving the z down
Acorn 4 pro license
4.99 beta ATC set up
Re: 4.99 beta ATC set up
Attached is current report. It still want to reset each tool after tool change. I use the 4.99 ATC set up in the wizard. It does not do this with 4.82
I reinstalled previous version version 4.82 and the ATC works without having to reset tool length at every tool change.
This appears to be an issue with the ATC wizard menu, not giving the option to change the TT after each tool option.
To work around this, can manually set Parameter 160 to 1. You will need to Initialize the ATC after doing so in V4.99.
Thanks for pointing it out.
Centroid PLC Tutorial Videos
