i agree. will tweak that.cncsnw wrote: ↑Thu Jan 12, 2023 2:17 pm One quick reaction after running v4.99r3 for the first time:
I definitely dislike the way that, as soon as you cancel a running job, it reverts to displaying the first 11 lines of the program, with line 6 boxed as if it were the current/active/last line of code that was running.
The longstanding behavior, that after a program ends or is canceled, the line that it was last running is boxed in the center of the display, was useful and intuitive.
If the intent of the new design is to show that -- because the job was canceled -- it has been reset to the beginning, then the box should be around line 1, not line 6.
in mean time, in the wizard, under CNC control preferences you can select "NO" to Part Program Preview on Job Load.
