Centroid CNC12 v4.99 rev3 BETA for AcornSix is now available
Centroid CNC12 v4.99 rev3 BETA for AcornSix is now available see
https://centroidcncforum.com/viewtopic. ... 122#p71122
for more information.
- CNC Control System Serial Number: Classified Information
Re: Centroid CNC12 v4.99 rev3 BETA for Acorn, AcornSix is now available
Thank you COLOR picker, welcome dark theme.
One glitch I encountered while installing (have no pics)
The network selection screen did not show names of the network adaptors to choose from
I had to choose between 4 adapters and only have two
something like this
() 0
() 0
() 0
() 0
I selected the first on the list and installation went smooth
Now onto the benchtesting
Yelleke
something like this
() 0
() 0
() 0
() 0
Yelleke
There are no stupid questions.
There are only stupid answers.
Is it possible to have a restart button in the shutdown menu
As I change settings in the wizard or change my VCP layout, I have to restart cnc12 many times
It would be super if there was a restart button next to Power Off or Exit CNC12
Yelleke
Yelleke
Also modified the feedrate override buttons and shrinked the reset button
Yelleke
Nice work Yelleke
in 2023 we will build an Centroid Screen Builder App that lets you create your own CNC12 screens any way you want in any order with any look etc..
thanks for the feedback.Yelleke wrote: ↑Fri Dec 23, 2022 3:05 am Thank you COLOR picker, welcome dark theme.
something like this
() 0
() 0
() 0
() 0
Yelleke
please give me details on the CNC PC being used.
Lenovo m93p with i5-4590T 2GH - 8GB - 120SSD
W10Pro 21H2 stripped down with NTLite (no cortona, telemetry, search, etc..)
With wifi adapter (was not connected)
One usb3 1GB ethernet dongle connected to internet. (forgot about this one)
One direct ethernet cable to Acorn. (you know, the blue one)
And if you count localhost loopback as an adapter, then it were 4 indeed.
But the names did not come thru, just zero's
Only 7 other apps:
CNC12, Firefox, Nomacs, VLC, Notepad++, syncthing and simplewall
Yelleke
Only 7 other apps:
Yelleke
Installed v4.99 a second time to see if I deleted the oneshot files like __ostrn.lth in Uwe his video
Then the network names came up like normal
Only two, the ones that were enabled
So, all is good
Yelleke
So, all is good
Yelleke
Re: Centroid CNC12 v4.99 rev3 BETA: CNC code display after run
One quick reaction after running v4.99r3 for the first time:
I definitely dislike the way that, as soon as you cancel a running job, it reverts to displaying the first 11 lines of the program, with line 6 boxed as if it were the current/active/last line of code that was running.
The longstanding behavior, that after a program ends or is canceled, the line that it was last running is boxed in the center of the display, was useful and intuitive.
If the intent of the new design is to show that -- because the job was canceled -- it has been reset to the beginning, then the box should be around line 1, not line 6.
