Hi all!
On the WCS table I really like that I can lock an offset to not accidentally make changes. However, I'd still like to be able to select it and hit "copy" (ctrl-c) so I can paste in a different offset. I can only copy it when it is unlocked. It seem like you should only lock "paste" and not "copy".
Thank you,
Corbin
WCS Table and Locked Offsets with Copy
- CNC Control System Serial Number: 3484E42757Cd-1018248693
Re: WCS Table and Locked Offsets with Copy
i moved this post into the beta software forum, thanks for the suggestion.
