Sure, here ya go. You need the dust collector too.
Much better than the AVID VCP
Uwe, with the latest changes to the PLC, the WMPG when active will "disable" the Encoder MPGs. This allows the WMPG to move all axes including the ones that have encoder handwheels. So WMPG must be "off", not on a valid axis to jog to enable the Encoder MPGs.suntravel wrote: ↑Sat Sep 28, 2024 6:11 am
Hardwired MPG on port3 for Z Axis is not working with the WMPG together
I have to set the WMPG to Spin or Feed and then turn the MPG button on the VCP on again.
That is like on my mill with USB BOB very annoying.
I am used to turn the MGP for Z axis and X on the WMPG right next to it without switching anything, that was perfect in R0 and all previous versions.
