CNC12 v5.1 RC#6 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Models: Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11
Download link
https://centroid-support.filemail.com/d ... 63393e70b5
changes from RC5
Fixed M115 not stopping when a TT is tripped when a NC Probe without a detect is connected and detect probe via tool number is turned on
Re: CNC12 v5.1 RC#6 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Here the new report after the installation of 5.1 cnc12.
At this time didn't test the system for trouble .
Is there something rongh with the report ?
do understand that line? in previous message.
(Fixed M115 not stopping when a TT is tripped when a NC Probe without a detect is connected and detect probe via tool number is turned on)
- report_E415F6F138CC-1119204064_2024-04-17_10-14-08.zip
- (900.42 KiB) Downloaded 2 times
Ok as this moment nothing as change .the axe that are plugin are moving as soon the power arrive.
need help .
thanks
need help .
thanks
is this the sigma 2 system? need photos and more information to help.
SIGMA 2 SYSTEM ???
acorn centroid with delta asda-b2 wiring system problem .
went cnc 12 and acorn is open , and I power up the the motor drive the x and z (only 2 axes are powered up for now) the motor start moving by it self.
What rough with acorn???
hi,
disconnect all but one delta drive from the Acorn.
enter delta asda software and perform a factory reset of the parameters.
confirm factory reset.
enter acorn delta parameters
confirm correct parameters
jog motor with asda software.
power cycle delta drive.
then test with Acorn
https://centroidcncforum.com/viewtopic. ... 724#p86724
