Wrong tool-offset calculation with Emcoturn 120 ( Rear Tool-Turret)
Re: Wrong tool-offset calculation with Emcoturn 120 ( Rear Tool-Turret)
we tested for it and found auto measure is working in your scenario but,
manual measure has a math bug in your scenario, it will be fixed in v5.2.
A beta will be released as v5.19 if you'd like to try it out before the official v5.2 release.
There is also another math bug.
Setting a tool to X0 with manual measure and rear approach it adds 2x Parameter 281, front approach is ok.
So I have to measure with front approach, and after measuring it set it back to rear approach.
And I thought I'm just doing it wrong
Thank you for the investigation!
German-speaking, so please be patient with my english-skills
thanks, we are on it. testing the fix on monday, when we get good results we will post a beta build for you guys to try out.
I moved this thread to the beta test forum
- Hickory CNC Controller: Yes
Hello,
We've implemented a fix intended to resolve both of the math bugs mentioned. Our tests with the X and Z offsets showed promising results, so we hope this addresses the issues you've been experiencing.
The build can be found here: https://centroid-support.filemail.com/d/rluihmtphqyvmrh
As a heads up to anyone unfamiliar with updating from previous versions of CNC12:
Please let us know if you run into any problems during installation or if this fix doesn't seem to resolve the issue.
Michael
- I'd recommend renaming and creating a copy of your cncm/cnct directory so you can easily revert back to an older version if desired.
- You can use Ctrl+P to automatically create a PDF screen capture of every menu in the Wizard.
- Avoid using restore report when installing to prevent any potential issues.
Michael
Acorn6 setup with Gang Tooling
Tool Measure with TT is ok for front and rear approach.
Manual X Measure rear also ok with X Diameter as a positive value
Rear tooling manual with X Diameter = 0 and nose vector 6 nok, it is adding two times the TT diameter to X like before.
Front with same tool and X Diameter = 0 is ok.
RTG is nok -> fatal error
- report_0008DC111213-0511220026_2024-06-26_18-09-27.zip
- (1.09 MiB) Downloaded 7 times
Thanks for the update! We'll get to fixing this as soon as we can.
Uwe,
Could you please provide a video of you performing each of your measurements with X Diameter = 0, especially the rear approach?
Thank you,
Michael
Thank you,
Michael
Hi Michael,
I do a video tomorrow.
