On the offset page the ATC button has dissapeared from the screen menu.
It was useful having the ATC button on the tool offset page now i have to exit and go to the MDI screen to change tools on the lathe turret.
V5.1 Lathe ATC has vanished
Re: V5.1 Lathe ATC has vanished
Parameter 6?
all your issues are from
intended work flow is: you must use write settings to cnc control at least once before moving the custom tool change slider to YES. we will make this more clear in the next version.
