tool sheet labeling?
How can I get my tool sheets to have the same program name and number as the G-code file I am posting? Mine always are labeled tool sheet for program 1001. I have looked in the post processor and other places but I have not found it yet.
Re: tool sheet labeling?
fusion360 uses the Program# you have written in SetupX\Post Process for the sheet.
Not in mine! I set the program number in the post processor say for example 1111 but my tool sheets always come with 1001.
Set the number in the setup for the toolpath, not in the PP setup
This is where the sheet gets the number from, and the PP also.
OK. That was the problem. Thank you Uwe! I missed you on the forum.
