Tool path for fly cutter
danno067
Post by danno067 »
Is there a way to program multiple passes with a fly cutter? I tried linear but it moves x and z at the same rate.
Re: Tool path for fly cutter
If you mean in Intercon, then look at the REPEAT command.
