Setting higher percentage than program speed
Scott Pancheau
Post by Scott Pancheau »
I am wondering if it is normal when increasing the percentage of program speed for the initial entrance moves to be way higher. Almost like a rapid move rather than the rest of the cutting travel. This only seems to apply when the percentage is increased ? It is almost like the travel is trying to catch up to a look ahead position ?
Scott
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Re: Setting higher percentage than program speed
Post by CNCMaryland »
Trying to understand what you are talking about. Is this about feedrate override?
Scott Pancheau
Yes, sorry if I am not clear. When the program is run at the feedrate set in Fusion 360 manufacturing, the entry and start to follow the machining path is smooth and at the set feed rate. If the speed over ride on the Centroid control screen is increased the entry and first approx. inch of travel is way faster than the percentage of increase set. If no one else is seeing this, then it must be some kind of a setting I have wrong. I am using nema 34 steppers from Stepper online.
CNCMaryland
There is another thread about this in the main acorn forum.
Scott Pancheau
I found the post about about the rapid override button. That seems to be about the opposite problem I am having. Can you be more specific about what post you are reffering to?
Scott
CNCMaryland
