Page 1 of 6
Dxf
Posted: Tue Nov 22, 2022 5:53 am
by Filardo
Hello when I create a dxf with fusion 360 some lines are non-existent on the cnc12 screen
Bonjour quand je crée un dxf avec fusion 360 certaines lignes sont inexistantes sur l'écran cnc12
Re: Dxf
Posted: Tue Nov 22, 2022 5:54 am
by Filardo
Does the new version of cnc12 fix this problem?
La nouvelle version de cnc12 corrige t'elle ce problème
Re: Dxf
Posted: Tue Nov 22, 2022 7:43 am
by suntravel
I think that is more a problem of how the DXF are generated...
If they have splines that will not work for Acorn, needs to be converted in curves and straights first.
Re: Dxf
Posted: Tue Nov 22, 2022 7:46 am
by Filardo
suntravel wrote: ↑Tue Nov 22, 2022 7:43 am
Can cnc12 read svg format
Cnc12 peux t'il lire le format svg
Re: Dxf
Posted: Tue Nov 22, 2022 7:47 am
by Filardo
Ou connaissez vous une méthode de conversation du dxf
Re: Dxf
Posted: Tue Nov 22, 2022 7:52 am
by suntravel
Intercon reads DXF files up to and including version R14. At this time, only point, line, arc, circle,
polyline and lwpolyline entities can be used to create Intercon operations. All other entities such as text
must be converted to lines and arcs for them to appear in the Intercon Import DXF menu.
Re: Dxf
Posted: Tue Nov 22, 2022 8:53 am
by Filardo
suntravel wrote: ↑Tue Nov 22, 2022 7:52 am
Disons que ça commence à me chauffer vu le prix du matériel et je m'aperçois que l'on peut pas faire grand chose avec
Désolé si je suis franc
Re: Dxf
Posted: Tue Nov 22, 2022 11:16 am
by suntravel
If you create a drawing in fusion, exporting dxf for import in CNC12 is not an efficient way to make something.
Why not let fusion write the g code, works perfect, no edit, runs as posted from fusion if set up right
Re: Dxf
Posted: Tue Nov 22, 2022 1:45 pm
by Filardo
suntravel wrote: ↑Tue Nov 22, 2022 11:16 am
J'ai pris centroid car option dxf m'intéresse pour pouvoir programmer le plus possible au Pied de la machine
Mais je suis de plus en plus dessus par les capacités de ce logiciel qui est très limité
Si je compare avec mon outil de travail itnc 530
Re: Dxf
Posted: Tue Nov 22, 2022 2:00 pm
by suntravel
ITNC 530 can also not read splines form DXF
And if you are complaining about costs, try to buy a new ITCN 530 from Haidenhain
