If you hit the sensors, soft limits are not set ok, or you are loosing steps...
.. I had this only with setting rapids (and frequencies ) to fast for the driver and wiring 5V to Headers with resistors
Cutter Compensation Question
Re: Cutter Compensation Question
Thanks Tom. How do I go about setting the soft limits?
Here is a screen shot of the current software travel limits. Can you please let me know specifically what I should change?
I just checked the Centroid installation manual (Section 7.15). Unless I am missing something, it appears that the software travel limits will help stop the machine from colliding with a limit switch. It does not prevent the machine from hitting a homing switch.
In my scenario, the machine is over-running the homing switch when a tool change is requested. The homing switch is located at the top of the Z-column.
Thanks... Richard
Thanks... Richard
You have the soft limits set 0.1" past the limit switch. Do you actually have this extra travel before the switch is damaged?
Hello Tom,
I do have extra space before the stop, but I do not think this is the issue.
When I started this post, I thought the problem was due to cutter comp. I now believe something is wrong with the homing switches affecting my machine coordinates. This is a problem I previously posted; thought was resolved... but now I see it has not.
I read the manual section 7.5 and found that the software travel limits only protect the limit switches. I only have homing switches, not limit switches.
To help clarify my question, I just reposted under "Centroid Acorn CNC Controller" a new post "Homing & Limit Switch Unsolved Mystery"
Thanks.... Richard
Thanks.... Richard
That is the issue. The one side of the soft limit needs to be zero. I replied to the other thread, make those .01" to 0 and you will not go past the switches.
Thanks.. I will give it a try.
