Simple question Re: Intercon Profile feed rate control
Posted: Mon Sep 23, 2024 12:00 pm
by kenmwallace
My Acorn system with Sureservo2 is working well generally. I'm setting up a production line for musical instrument such as clarinets etc.
I use Profile in some steps of my process. When the tool enters the work, it does so as a rapid move which is too fast.
I see in the Turning feature that there is a way to select entering and exiting at feed rate. I don't see a similar option for the Profile feature.
Am I missing something?
Re: Simple question Re: Intercon Profile feed rate control
Posted: Mon Sep 23, 2024 12:30 pm
by tblough
Post the Intercon program you are using (the .icn file, not the generated g-code). Intercon should use the federate of the first move into the part. If you are programming a first move that is less than the actual diameter of the stock, then it will rapid to the start of the first move, and therefore into the stock.
Posted: Mon Sep 23, 2024 1:16 pm
by cncsnw
Yes, the first move (from the "start" point, which is really the clearance point; to the beginning of the profile itself) should be a feedrate move if it is going to encounter materlal; and can be a rapid move if it is fully clear of the end of the stock.
Since you are probably turning between centers (no free end), it is likely you need to use a feedrate line for the first move.
Also on the profile screen, you will want to select "Rapid Between Cuts: No". That will ensure that the plunge to each new depth, in concavities in the middle of the profile, is also done at feedrate and not at rapid.
Posted: Mon Sep 23, 2024 2:49 pm
by kenmwallace
I thought about de-selecting "rapid between cuts", but I am making long lateral cuts, so the return at feed speed of 5 ipm would take 2 minutes.
Posted: Mon Sep 23, 2024 9:09 pm
by suntravel
kenmwallace wrote: Mon Sep 23, 2024 2:49 pm I thought about de-selecting "rapid between cuts", but I am making long lateral cuts, so the return at feed speed of 5 ipm would take 2 minutes.
I am using always rapid between cuts, with ok selection of entry path and depth of cut there is no problem.
Graph with 50% Feedrate to make sure the tool tip will not hit the part with rapid moves.
Posted: Mon Sep 23, 2024 10:57 pm
by cncsnw
I am pretty sure that "Rapid Between Cuts" only applies to X axis infeed, not the Z axis return.
Correct me if I'm wrong.
Posted: Tue Sep 24, 2024 12:11 am
by suntravel
cncsnw wrote: Mon Sep 23, 2024 10:57 pm I am pretty sure that "Rapid Between Cuts" only applies to X axis infeed, not the Z axis return.
X infeed and moving in Z to a deeper part of the profile
Return in Z is always a rapid move
Posted: Tue Sep 24, 2024 10:31 pm
by kenmwallace
Thank you Forum Contributors!
My assumption about the meaning of "Rapid Between Cuts" was wrong and led me to discount that as a solution.
Toggling that to NO fixed my problem without making the Z axis return at feed rate.
Ken Wallace
San Diego
