Hello, how can I get information to make a thread with the api reg 3-1/2 box specification, in steel, in a milling machine.
Tools?
3.5 api reg thread gcode mill
Re: 3.5 api reg thread gcode mill
You need a thread mill to cut this on a mill, or use a boring bar from a lathe with a threading insert to mill it, but that is very slow.
You'll need thread specs for the thread:
https://pslcolombia.com/documentos/TechFacts.pdf
Most important (and most expensive) you'll need a plug gage to check the thread. Since it's a tapered thread, there is no other way to measure it in the machine.
Vargus makes toolholders and carbide inserts for oilfield threads.
Vargus USA
https://www.vargus.com/Vargus/userdata/ ... D=1&GID=36
Vargus USA
