Torch Not firing during Test fire
Posted: Sat Mar 16, 2024 1:22 pm
Hello,
I am having an issue testing firing my plasma torch Hypertherm 45xp I am currently just trying to test fire, as I'm still waiting on parts/hardware to wrap up my panel build and table build.
I have previously run the bench test for the voltage, ( I switched back to CNC mill for a project)
I am using a magnetic breakaway with torch tip touchoff wiring via schematic s15107
Via the PLC menu the torch tip touchoff is working - when grounded turns green
and the breakaway turns red - when torch mount is broken/triggered
When I go to test fire, it seems as the button is dead, No relay switch no fire from the torch.
What could be some things to check for? Did I miss something or a setting in the Manual?
Does the orientation of pin 3 and 4 from the cpc cable to the relay for torch on matter?, it is not specified on S15107
Is this a ground issue? (since the table is not complete I have not finished grounding the axis's via the bulletin) but even if I take the torch ground and clamp it to the Hose bracket holding the voltage sensing wire the torch will not fire in air.
Since it was a new install for acorn plasma free do I have to rerun the bench test?
Any thoughts or insights would be greatly appreciated.
I spoke with Joey at the end of the day Friday when I called in asking about CNC plasma Free, And told him he might see a post, and here it is.
