thc encoder error
thc encoder error
we have cut several parts this morning with ease we are getting a 9105 encoder error both tx and rx boards are getting power fiberoptic cable appeares to be fine any ideas?
Re: thc encoder error
Can you attach a fresh report.
Is the encoder error intermittent?
A loose encoder cable could also cause an encoder error.
attached is a current report any ideas would be helpful after trying different things i noticed when we disable thc machine will move again and operate normally yet no thc enable thc and 9105 encoder error prevents everything from moving
- report_3484E4263288-1013237522_2023-11-28_07-16-24.zip
- (3.4 MiB) Downloaded 38 times
Looking through the Plots in the report I'm not seeing any voltages read in any plots.
Did you do a calibration cut?
Do you know the THC was ever working?
What Plasma cutter do you have?
