Powermax 1000 g3?
Moderators: cnckeith, Joey
Joey
Re: Powermax 1000 g3?
Post by Joey »
The profiles provided are not older 1000 G3 profiles.
It is important to calibrate to the Hypertherm cut chart so that your voltages and speeds match up throughout the cut chart for that model.
Just adjust the name and add your models cut chart information to the profile to calibrate with. Then add the other cut chart data to create other profiles.
There is no cut charts for the china cutters. I'll have profiles to calibrate too shortly but at this time china cutters will need there own profiles figured out. Should have profiles for Primeweld and Everlast in the Next couple weeks.
BoenBuilt
Post by BoenBuilt »
Joey wrote: Mon May 29, 2023 12:38 pm The profiles provider are not older 1000 G3 profiles.
Ok, I think I understand now. I thought it mentioned something about having to use a provided profile for calibration, but it meant to use settings specific to your plasma model 👍 I'll play with it more today.
landmark573
Post by landmark573 »
Did your PM1000 have the voltage divider or were you able to purchase one from Hypertherm? I'm hoping to get one at an auction but would like to know if those parts are available.
BoenBuilt
Post by BoenBuilt »
landmark573 wrote: Mon Jun 05, 2023 12:20 pm Did your PM1000 have the voltage divider or were you able to purchase one from Hypertherm? I'm hoping to get one at an auction but would like to know if those parts are available.
Bought the cpc with voltage divider from hypertherm.
