Hello,
I am buying a router table soon that I will convert to plasma.
I am wondering if it's possible to do milling and plasma on the same Acorn controller ? I will do a special modified Z and special removable table.
Is it only a matter of using different software License ?
Eg. Depending what I want to do, I open Milling software or Plasma software ?
I am o.k. to buy both licences (Mill + Plasma)
Best regards
Possible to do Milling and Plasma on the same Acorn ?
- CNC Control System Serial Number: 4469
“Better to try and fail than not to try at all.” -Nicole Krauss
AXYZ Millennium router CNC: https://goo.gl/gxvdcA
Glass cutting CNC table: https://goo.gl/VrDqGD
Re: Possible to do Milling and Plasma on the same Acorn ?
yes, no problem.
yep you will need both license files, Router Pro or Mill Pro and Plasma Pro.
