I am having issues cutting corrugated. I am using the recommended settings,have calibrated the torch, slowed the speed down anywhere from the normal cut speed to 75% slower. Table is grounded properly, torch touch off works. THC works good on thin aluminum that warps, and steel that I cut. I have been 10% higher and lower on Anti Dive Ratio and Anti Dive Threshold.
It just seems like the torch isn't adapting fast enough or properly?
Video:
Corrugated Issues
Corrugated Issues
- plot.xml
- (3.85 KiB) Downloaded 6 times
- msg_log.txt
- (357.16 KiB) Downloaded 5 times
- msg_cnt.txt
- (2.15 KiB) Downloaded 7 times
- Plasma/Laser Lead
Re: Corrugated Issues
What is the X and Y and Z Accel decell settings?
Can you attach a picture of the Wizards Configuration menu please
Try a higher cut height to give the Z axis more time to react.
Do you have a THC plot capture of the Cut in the Video?
If so please attach a snip picture of the plot.
How much higher? I have been up to .15 cut height with not much success.Joey wrote: ↑Sun Jun 02, 2024 6:47 pm What is the X and Y and Z Accel decell settings?
See attached for plot and config.
I may have found the cause...but would like some reasoning.
When a cut was interrupted and you go to restart by setting the position, it disables Auto THC control. Any way to make sure that doesnt happen?
- Plasma/Laser Lead
Speeding the Z up more should also help. 200ipm max rate could be better. Max the Z out and find its limit.
I'll look into THC turning off when in restart. Restart should reset all settings back to how they were set when entering restart mode.
- Plasma/Laser Lead
Have you made any more progress?printcutfab wrote: ↑Sun Jun 02, 2024 6:35 pm I am having issues cutting corrugated. I am using the recommended settings,have calibrated the torch, slowed the speed down anywhere from the normal cut speed to 75% slower. Table is grounded properly, torch touch off works. THC works good on thin aluminum that warps, and steel that I cut. I have been 10% higher and lower on Anti Dive Ratio and Anti Dive Threshold.
Video:
Can you Post a fresh report?
I can do a team viewer session to help tune these settings.
