MPG Plasma Lost RF
Moderators: cnckeith, Joey
Re: MPG Plasma Lost RF
BryanDowdy wrote: Wed Jan 24, 2024 9:35 am
cnckeith wrote: Tue Jan 23, 2024 3:04 pm thanks, yes.
there still are a fair amount of com errors in the error log.
what are the results of running the com stess test.cnc
The stress test passed with zero errors. What are COM errors?
report_20D778803C24-1011237516_2024-01-24_06-33-54.zip
link to thread showing how to solve com errors. lots of details to get right.
com = communication errors. this is communication between the Acorn and the CNCPC
what run the included com_stress_test.com program , what results do you get?
BryanDowdy
Plasma CNC Controller: Yes
CNC Control System Serial Number: 20D778803C24-1011237516
Post by BryanDowdy »
[/quote]
[/quote]
I went through the entire cnc pc setup again and ran the PC tuner again. Only thing I found I missed was the IP address being automatically assigned. I corrected that and have attached the report below. I also attached the results of the stress test. I did try the WMPG again after this and it's still not working. I will say, I've been running cnc12 cutting without issues.
BryanDowdy
I have the WMPG enabled in CNC12. If I unplug the USB receiver and start CNC12, it gives me a warning. So I'm guessing CNC12 is seeing the receiver. Is there a way to re-link the WMPG to the USB receiver?
BryanDowdy
cnckeith wrote: Wed Jan 24, 2024 2:40 pm link to thread showing how to solve com errors. lots of details to get right.
Keith, any update on what I need to do next?
BryanDowdy wrote: Wed Jan 31, 2024 11:47 am
did you solve the com errors? if so how? and please post a fresh report.zip
BryanDowdy
Joey wrote: Wed Jan 24, 2024 12:24 pm Hello Byan,
The Com errors are Packets that are sent between the Acorn and the PC.
I checked out your THC plots and there's interference. Have you fired the torch yet?
I wouldn't advise it until the Ground loop or interference is sorted.
I'm thinking that this is related to the COM errors and the USB transmitter.
Have you tried the USB and MPG on a different computer away from the cabinet?
Just to ensure the MPG does connect.
Can you start a google photo Album so we can See the Cabinet?
Joey, I must have missed your reply.
How can I check for com errors myself?
Yes, I've fired the torch. I've cut 3 sheets already.
I did try it on a laptop in my office, it did not work on it.
Yes, I will work starting a album.
Unfortunately, I'm going to have to pull of this project for a bit. I'll update this thread once I can get back on it.
BryanDowdy
cnckeith wrote: Wed Jan 31, 2024 5:16 pm
Keith,
I went through the entire cnc pc setup again and ran the PC tuner again. Only thing I found I missed was the IP address being automatically assigned. I corrected that and have attached the report below. I also attached the results of the stress test. I read through your link on how to correct com issues and I believe I've done everything. The stress test comes back with no errors.
ok great. sounds like progress.
BryanDowdy
cnckeith wrote: Thu Feb 01, 2024 4:21 pm ok great. sounds like progress.
Keith, I'm back on this project. I've attached a current report. Stress test comes back with 0 errors.
Control cabinet: https://photos.app.goo.gl/5xZtc9oa2J7Jn6XF9
There is a metal box that goes over THX card.
BryanDowdy
Joey,
My google album is: https://photos.app.goo.gl/5xZtc9oa2J7Jn6XF9
I've gone through and I believe I've sorted out the ground loops. Can you tell me how to read the report to confirm this?
