Hello,
We are trying to mill an outside circle with the ARC module in Intercon. In the ARC we choose CP & A.
We start with a straight G0 movement outside the workpiece and connect the ARC to the G0.
After posting we keep getting stuck in module N0001 on lines 13 (M41) and 15 (M40).
As far as I understand, these M codes relate to the spindle speed, and the error message (Turn off/on Z axis MPG mode) has nothing to do with this (see photo).
As a 2nd test, we called up an M40 and M41 via MDI and that gave an error [503 Invalid M function] (see photo).
The spindle motor has only 1 speed.
Please help
ARC in Intercon gives an error
- report_0008DC111213-0225211105_2024-02-21_15-30-02.zip
- (4.67 MiB) Downloaded 4 times
Re: ARC in Intercon gives an error
Please post your Intercon file.
pascalken: unless your machine is a waterjet, change Parameter 19 to 0.
Centroid: fix the wording in CNC12 parameter descriptions, and in the operator's manual, so that people don't get the mistaken impression that they need to set P19 += 4 in order to use their MPG handwheel for the Z axis of an ordinary milling machine.
done, new cnc12 description for P19
MPG Options:
Default value = 0
Add 2: Z axis MPG speed selection "x100" will be the same as "x10" (Safety Feature)
Add 4: Allows manual adjustment of the Z axis position on the fly while running a G code job using the MPG. (Typically used with Flame/Waterjet)
Add 8: Set the Macro 1 button function on the WMPG-4 as a Torch On/Off button (Plasma)
