Hi, working through the bench test using the latest release of the manual and I have found an anomaly between the text and the illustration.
On the Drive Bus allocation section the text says to set parameters 300, 301 and 303 i.e. skipping parameter 302, however the figure 4.1.7 shows that 300,301 and 302 are set.
Which is correct.
Neil
Manual error?
Re: Manual error?
You are correct, this is an error. It should read Parameter 302 = 3.
I will get that corrected soon.
Domenic
