Recent upgrade from Linux system
Allin1DC
CNC12
Windows11
Parameter 4, is set to 8
I can't see our mapped drives while in CNC12, I can see the USB drives and C drive.
The mapped drives are visible and accessible from Explorer on the NUC.
What am I missing?
Bewildered Bryan
Ayers-Tech.com
Parameter 4, CNC12, Windows11, Allin1DC, I can't see mapped drives <resolved>
- CNC Control System Serial Number: 0419070936
Re: Parameter 4, CNC12, Windows11, Allin1DC, I can't see mapped drives
How does the CNCPC connect to the networked drives?
Domenic
We have a CAT6 network cable connecting it to our network hub.
Do you have drive letters assigned to the network drives?
Or, when in Windows, do you just access them by server name and share name?
Assuming you have drive letters assigned, do they appear in the CNC12 F2/Load menu, if you set Parameter 4 = 5?
Assuming that you have dutifully told Windows to "Run as Administrator" when running CNC12, try un-checking that choice and see if that helps. In other situations (Windows Pro with domain authentication) I have seen Windows restrict access from cncm.exe running as administrator, even when the unprivileged user account has access.
Funny, I was just coming back to my desk to let people know I solved it.
This morning, I unchecked "run as administrator" and the mapped drives show up!
Thanks for all the help!
Bryan
Bryan
