Cnc10 takes forever to read in the directory
- CNC Control System Serial Number: CNC12-m39-104028
Anyone ever seen cnc10 take forever to load its directory?
Rob Jackson
RJ Technical Services
Re: Cnc10 takes forever to read in the directory
hard drive issues? full? corrupt?
I have found that is typical behavior with CNC10 v2.3x when reading my field-work USB drive, which contains over 400 folders. Well, not "forever", but often a minute or two.
CNC10 v2.7x has no problem reading the same USB drive promptly. CNC10 v2.7x uses a newer Linux kernel.
I do not recall seeing significant delays with CNC10 v2.3x reading its own hard drive / flash card, nor reading a USB drive that contains just a handful of items.
Thanks for the reply Marc and Keith.
It started when we changed the motherboard. We are using the same flash harddrive Centroid supplied. I don't know the Linux OS at all. I'll check the directory and see if any large files are slowing up. What the best method for checking a Linux harddrive for corruption?
Thanks for your time,
Rob
Rob
Rob Jackson
